TwinTurbo.NET: Nissan 300ZX forum - Not quite, power is fed TO the ECU and injectors from either
Subject Not quite, power is fed TO the ECU and injectors from either
Posted by 300zx90 (CO) on May 18, 2006 at 9:22 AM
  This message has been viewed 393 times.
In Reply To I'll check it out this weekend on my 90 and post a posted by DAYTONAZ on May 17, 2006 at 08:10 PM
Message the battery or ignition switch. If the power was coming from the ECU, the a pin swap might be possible, but in this case only the ECU itself would see the change (injector power would be unaffected). The common injector lead needs to be disconnected from the lead on Pin 58 (while leaving this lead intact so pin 58 still receives constant power), and spliced into the lead on Pin 45.
________________________________________
NA to TT, starting from the ground up...
